VXI and VME
E1383A VXLink Kit + E1326B multimeter
This question is about HP hardware, but I think that it makes sense asking here since there maybe some NI software available as a solution.
I have an old system composed by an HP E1383A VXI ISA Card Interface (witch I have no drivers for them, and can't find anywhere, for any operating system) and an HP E1326B Multimeter on the same system that I can't have access to it.
I was able, however, to establish some sort of connection with bits and pieces of a program named EPConnect from Radisys (dated 1994) on Windows 98, but it seems that this program and drivers are for Windows 3.11 and I can't see the board any where on the device manager of Windows 98.
I also have found drivers for the multimeter board (HP E1326B) on:
http://www.home.agilent.com/agilent/techSupport.jspx?pid=1000002431%3Aepsg%3Apro&pageMode=DS&cc=US&l...
but, if I can't get access to the ISA Board (HP E1383A), how can I have access to the multimeter functions?
Is there any way that I can resolve this problem?  On any operating system?  How can I have access to the ISA board and the multimeter?
As a last technical detail, I have found that I can communicate with the ISA board through:
ISA Card I/O: 0x4230
VXI Module Port Address Base: 0x8230
IRQ = 10
Using the Radisys software (I can see that the board is really there).
Any help would be very appreciated, and thank you in advance for reading,
Eng. Marco Ferra
(7,924 Views)
Hello Marco,
This is a big one!
Well, what can be done on our side is to provide you with a PCI-VXI or USB-VXI solution because ISA isn't on our catalog no more. This would allow you to control your VXI easily. I wish I could help you more, but there's no solution for your system. It is too hold!
By the way, thanks for posting here your questions (even on non-NI products :D)
You can call us and ask for direct assistance or advises if you wants to go forward.
BRAUD Jean-Philippe
Field Sales Engineer - Nord et Centre France
LabVIEW Certified Developper
(7,912 Views)
Oh I see. It's an old system indeed...
Can you recommend a PCI-VXI (not USB) solution to this application?
(7,905 Views)
In order to connect a computer to a VXI system, we can provide you with MXI-2 or MXI-3 solutions. Please follow this links to learn more about this "starter kit". Of course, you can purchase parts of this system only.
BRAUD Jean-Philippe
(7,901 Views)
