VXI and VME
How do I add another VME frame to an existing PCI-MXI-2 configuration
I have an existing VME Frame that is in use via a PCI-MXI-2 interface.
Using Max Explorer(v.5.0.1), how do I add another VME frame, with other devives, to the existing PCI-MXI-2 configuration?
I did this 10+ years ago, and don't remember the steps.
Dave Bolles
(7,960 Views)
Hi Dave,
Given the age of VME hardware, support resources are a bit sparse. I was able to track down a PDF (linked below) that walks through the process of configuring a VXI system in MAX -- the steps might not align exactly with your particular version of NI MAX, but they should provide some guidance nonetheless.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/97b8441ebf716dbd862569ee00562083/$...
Let me know if this is enough to get you going. I'll spend a bit more time today searching for additional documentation and will post back if I track some down.
Best,
Nik H.
(7,943 Views)
Nik,
I was able to get another Frame recognized, but it was very intermittent.
Swapping cables and MXI-2 cards made no difference.
Note: On the machine that I am having issues with, I was running NI-VXI with the following:
NI VXI 2.11
Visa Run time 5.3
Visa 5.3
NI DAQ Max Configuration manager 9.5
System Configuration 5.1
I was unable to Import/Export VME devices so I decided to upgrade NI-VXI to 3.5.
Note: I am running NX-VXI 3.5 on XP on another PC and have had no issues.
Now I am running into compatibility issues with NI-VXI 3.5, when running Resource Manager, see attached.
How do I fix this?
Dave
(7,927 Views)
Nik,
This article did not help me.
NI has to do a better job of identifying the appropriate links for a particular task.
A better article is:
https://www.ni.com/pdf/support/us/multfrm2.pdf
It took me 3 days to find this.
I been talking with tech support for 4 days now, still no solution.
Dave
(7,870 Views)
