VXI and VME
How many pins have the ANSIC MANTIS and MITE each?
I am using the PCI-MXI-2 and VXI-MXI-2.The core of the two modules is the ANSIC which is developed by NI.So I plan to learn how to use these two ANSICs.
(6,414 Views)
Hello laidesheng,
Detailed knowledge of the MANTIS and MITE ASICs is not required in order to use NI's MXI-2 products, as you can use the NI-VXI driver for your programming needs.
If you are looking for resources to develop your own MXI and VXI based products, then some good starting points are:
National Instruments KnowledgeBase: What is the PCI-MXI-2 Driver Developer Kit?
Also, you can find more information on the VXI specifications at the VXI Consortium webpage (http://www.vxi.org/)
Joshua Hernstrom
PXI/VXI Support
(6,414 Views)
