VXI and VME
[MAX] Problems setting the size of my PCI user window
Ok, this may be a very dumb question but I'm just starting to use MAX so please bear with me.
On my VXI system I need to change the size of the PCI user window from it's default 64KB to 16 MB. Therefore, under MAC I went to the PCI setting tab and tried to change it to the desired size. Everytime I try to change it it shows the following message:
"Unable to save configuration changes.
Unable to access configuration information
[-405]"
I guess this means that the configuration file that stores this value in either corrupted, missing, etc. Or that I cannot change that window size in my current system. Does anybody have an idea on how to solve this little problem? thank you.
(6,592 Views)
Sorry, on the second paragraph it should say "under MAX" not "under MAC".
(6,592 Views)
Hello!
I have a few questions about your configuration. What Operating System are you using? If it is Windows NT/2000, are you logged into an administrator account? If not, do you still get that error when logged in to an administrator account? Also, what VXI controller and version of NI-VXI are you using?
(6,592 Views)
