VXI and VME
MXI-2 to MXI Conversion cable
I am looking for data sheets, specs, part numbers, etc. anything concerning the cables required to connect PCI-MXI-2 (144 pin square connector) to MXI (62 pin D connector)
I may be blind or stupid, or quite possibly both, but I have had no luck locating this info on the NI website.
Any help is greatly appreciated.
Don
(7,327 Views)
Hi Don,
There is no way to adapt a MXI cable from one generation to another.  All equipment from a MXI Kit should be limited to the same generation.  Post back if you have more questions.  Best of luck to you!
Regards
Dustin D
(7,311 Views)
Thanks for the reply.
That's not very encouraging, but luckily I found the info I need elsewhere.
Don
(7,309 Views)
