VXI and VME
MXI-3 not working get error 10401 from max
get error 10401 when triying to access cards in PXI1000 chassis using MAX test panels
(6,224 Views)
The 10401 error is usually indicative of a problem with a DAQ card, not a MXI-3 card, but anything is possible. I will give you some general tips for troubleshooting the MXI-3 kit, but the DAQ card could ultimately be the problem.
First, do you have the MXI-3 Optimization Software installed? If so, does it run properly on boot up? This software should detect the presence of the MXI-3 link. If the optimization software is having problems running, I would recommend emptying your chassis of all cards but the MXI-3 and try booting up and running the software. If problems persist, you could try changing the PCI slot of your PCI-MXI-3 card, or, if you have other MXI-3 hardware available, you could switch pieces between the kits. You could even try the system with ano
ther PC.
If the MXI-3 kit is working properly, then the DAQ card or the chassis could be causing the problem. Have you tried any other cards behind the MXI-3 link? Have you tried the problematic card in multiple slots? Was the system ever working properly? If you feel the DAQ card is the problem, I would recommend creating a new support thread so that we can get our DAQ Applications Engineers to help you troubleshoot the issue.
Here is a link to more troubleshooting tips for MXI-3:
http://digital.ni.com/public.nsf/websearch/484f81e6570ad803862569ed007aaa41?OpenDocument
Ryan Tamblin
(6,224 Views)
