VXI and VME
National Instrument Software Crashing VXI Processor
Everytime I work with MAX v3.0 the Windows 2000 based VXIPC-872B that I have crashes. Upon recovery, the Event Viewer says that " The computer has recovered from a bugcheck located at 0x00000076 (0x00000000, 0x822df8e0, 0x00000001, 0x00000000) Microsoft Windows v15.2195 ..." It goes on to say that a memory dump has occured. What is causing this? How can I fix this problem?
(6,666 Views)
Hitman-
The 872B is a normal PC in a different form factor. So the fact that it is VXI is not going to cause this problem. Have you already tried repairing your MAX installation? It is possible if there was an error during the initial installation that something like this might occur. What hardware are you using with the VXI Chassis? Does this problem occur even when the chassis is empty? Sometimes these types of problems occur when HW conflicts are present.
I hope this helps. If you are still seeing the problem, let me know which other NI drivers you are using, and specifically, which one installed MAX 3.0 that you are using.
Dustin
(6,666 Views)
