VXI and VME
Recommended VXI drivers for Windows 7
I am upgrading a test station from Win XP using TestStand 3.1, CVI 7.1, and LabView 7.1 to Windows 7x64 TestStand, CVI, and LabVIEW 2012.  The interface to the test station is VXI-USB and GPIB-USB-HS.  I currently use DAQmx 8.6.1, VXI-3.5.1, and NI-488-2 v2.3.
What are the recommended versions of DAQmx, VXI, and NI-488 for Windows 7?
(7,209 Views)
Hi Gary@B,
The newest version of NI-VXI (3.8.1) should work fine with your controller. You can check this KnowledgeBase for the compatibility information of NI-VISA with certain controllers (its a few months out of date). NI-VXI includes NI-VISA and MAX and should be sufficient for programming your system. If you would like any other drivers for any reason, such as your using a PC to access your VXI system, the newest drivers should work fine.
Best,
Jason M.
(7,199 Views)
