VXI and VME
Resman has fatal errors when run from start menu
I have a VME chassis connected to my computer via an NI MXI-2 bus.  When I run resman out of MAX, it works fine.  When it automatically runs on startup or when I run it from the start menu, it bombs out with a windows fatal error.  This has happened for years, on multiple different computers.  This isn't a huge deal, so I haven't investigated it before.  Is this a known bug?  Is there a way to fix this annoyance?  I'm running latest driver versions of everything, although the VXI driver has remained static for quite some time from NI.
I just discovered the different operation today - start menu vs. in MAX.  I think it may be a clue...
(6,771 Views)
This is somewhat of a known issue.  Take a look at the following KB:
http://digital.ni.com/public.nsf/allkb/851CD72FA50001B0862571100081237B?OpenDocument
Chad B. » National Instruments » ni.com
(6,763 Views)
