VXI and VME
TOT PON TM error displayed on VXI
Has anyone had this error message on the VXI?  I have no technical info on hand to enlighten me.
(8,440 Views)
Hi Joshua,
I wasn't able to find anything related to this in our database.  What VXI hardware are you using?  Do you have any other context for the error and when it occurs?  Does the error mention anything else / could you post a screenshot?
Michael Keane
(8,404 Views)
Hi Joshua,
I wasn't able to find that part number you messaged me anywhere in our system.  Could you describe the hardware set-up (chassis, controller, modules, drivers)?
More importantly though, could you provide more context for the error and what is happening at the time of the error?  Any additional error codes, messages, explanations of that acronym, screenshots?
Because documentation for VXI is limited compared to PXI, it may be a good idea to continue crowd sourcing with the community in case this error is smaller in scope.
Michael Keane
(8,376 Views)
Let's see if this helps.  I have 6 slots with cards.  the first slot has a IEEE-1394 controller, then a VXI bus simulator, next is a waveform generator, fourth is a VXI waveform digitizer, fifth is digital multimeter.  Sixth is a multicard modular switch, with 2 high density plug-ins, 2 power switch plug-ins, and 2 RF multiplexers.  There are no fails that i can see associated with this error code.  I have no tech data that would describe what the error code means.  This VXI chassis is part of a test station used for testing a USAF item.
(8,364 Views)
I unfortunately can't find anything related to that acronym internally - I'd welcome any other community member to comment if they can shed any light.
Michael Keane
(8,345 Views)
