VXI and VME
VME-MXI-2
Hi all
Resman is held up when it tries to configure the mainframe corresponding to the VME-MXI-2 device.
I am unable to load the hardware configuration for the device (-102).
The settings of the cards are the factory settings.  However I believe I changed the requeted memory from 16k to 4k and that is the card and resman started having problems.  Please help me.
EliAlca
(7,169 Views)
Hi alcaEli,
Have you tried to configure the VME interface back to the 16k memory to see if this helps?
Best,
Adam
Academic Product Manager
National Intruments
(7,164 Views)
EliAlca-  why did you change the requested memory size? Did you install DRAM? I think you should check out the VME-MXI-2 User Manual (start at page 183).
Hope this helps! Go State!
(7,025 Views)
