VXI and VME
VXI-MIO-64E-1 in LabWindows/CVI
I am using VXI-MIO-64E-1 module for Data Acquisition of differential Signal of 0-10V. By default Module is configured in -5V to +5V. I have used  status = AI_Configure (deviceNumber, chan, inputMode, inputRange, polarity, driveAIS) function for configure module to 0-10V unipoler but  still module is taking -5V to +5V not 0-10V.  here is LabWindows/CVI code for configuration of analog input module.
    buffer = (short *)malloc ( NUMPOINTS * sizeof(short));
   status = Init_DA_Brds (1, &brd);
   if ( status != 0 )
    MessagePopup("Error","Error in initializing VXI device");
    exit(-1);
   status = SCAN_Setup (1, NUMMODULES, ChannelList, ChannelGain);
   if ( status != 0 )
    MessagePopup("Error","Error in configuring VXI device");
    exit(-1);
   status = DAQ_DB_Config (1, 1);
   status = DAQ_Config (1, 1, 0);
   status = Select_Signal (1, ND_PFI_7, ND_IN_SCAN_IN_PROG, ND_LOW_TO_HIGH);
   if ( status != 0 )
    MessagePopup("Error","Error in Configuring SCAN_START input Line");
    exit(-1);
   InitializeTimer1();
   /* Module 1 Initialization Over */
   /* Module 2 Initialization Starts */
   buffer1 = (short *)malloc ( NUMPOINTS1 * sizeof(short));
   status = Init_DA_Brds (2, &brd);
   if ( status != 0 )
    exit(-1);
   status = SCAN_Setup (2, NUMMODULES1, ChannelList, ChannelGain);
   if ( status != 0 )
    MessagePopup("Error","Error in configuring VXI device 2");
    exit(-1);
   status = DAQ_DB_Config (2, 1);
   status = DAQ_Config (2, 1, 0);
   status = AI_Configure (2, -1, 0, 10, 1, 0);
   /* Module 2 Initialization Over */
What mistake i am doing to configure module-2 to 0-10 Volt input range.
(6,883 Views)
Hello Vishnu,
Unfortunately, the VXI-DAQ cards are no longer supported, but you can find information about using them in the manual.  The VXI-MIO Series User Manual  has details about setting the input range in Chapter 3 on page 3-4.
Good luck with your application!
Meghan
(6,853 Views)
