VXI and VME
VXI-MXI upgrade
I have the executable and source code, can i use the same code which is written in Labview version 3.1 & 4.0 to recompile it to latest labview version to be run on windows 10?
I know that for Labview verion conversion i will have to port the code to intermediate version and then finally compile it in latest labview version.
What i wanted to know is Driver files of VXI-MXI bus are written for windows 95 can i use same driver files for windows 7 or 10 in order to communicate with same hardware ?
or Can i port the same code to PXI based hardware ?
Thank you.
(4,325 Views)
I'm not super sure about the driver capability, though it's worth trying.
Porting the code to PXI platform might need modifications to work with native PXI instrumentation drivers.
(4,072 Views)
