VXI and VME
VXIpc-872 freezes after restart or after BIOS update save
I have a VXIpc-872 Slot 0 Controller.  Unit will boot windows NT from Cold start, but performing a windows restart or following any BIOS modifications the controller freezes.  Only get a solid black screen.  Power OFF has been the only way to clear it.
Any thoughts on what might be wrong?
Message 1 of 8
(9,924 Views)
Hi Jaley,
Had anything recently changed with your set up? ie the BIOS or operating system version? Has your VXI system always done this?
Scott M.
Message 2 of 8
(9,921 Views)
Hi Scott,
Nothing has changed with the setup and it has not always done this.
Jason
Message 3 of 8
(9,918 Views)
Hi Jason,
Sorry about the delay. I have been checking to see if there are any BIOS updates available for your controller, there aren't. So your best option is probably to reset all BIOS options to their defaults, and format your controller.
It doesn't seem that there are any easier fixes.
Scott M.
Message 4 of 8
(9,887 Views)
Scott,
I reset the BIOS by moving the W6 jumper.  After reconfiguring the BIOS to our setup, it took the controller about 30 seconds before the reboot started.  I then entered the Symbios SCSI Configuration utility and reviewed that setup.  After closing and saving, the controller never performed the reboot (waited about 15 minutes).  I pushed the reset button and still no reboot.  Will only reboot after a cold start.
I use an external SCSI hard drive that is good.  What steps are needed to "format your controller" as you stated previously?
Thank you,
Jason
Message 5 of 8
(9,877 Views)
Hi Jason,
We have a really good Developer Zone article on the subject, you can find it here.
Restoring or Changing the Operating System in a VXIpc-770/870B Series Embedded Controller
http://zone.ni.com/devzone/cda/tut/p/id/3988
Scott M.
Message 6 of 8
(9,865 Views)
Seems like reloading the OS on a clean hard drive has improved the units performance.
I will keep working with it to see if it starts freezing up again.
Jason
Message 7 of 8
(9,846 Views)
Glad to hear it Jason, keep me posted if anything goes wrong.
Message 8 of 8
(9,844 Views)
