VXI and VME
how does an application using VISA recognises the instruments connected to it
I read that an application using VISA calls uses an instrument descriptor to recognise a device.
I want to know how an application recognises  the instruments connected to it and how the unique instrument descriptor is assigned to the individual interfaces
(7,025 Views)
The instrument descriptor is assigned by VISA to each device that the device driver returns.  For GPIB this is done when you scan for instruments from Measurement & Automation Explorer (MAX).  Every address on the bus is queried and an instrument descriptor is assigned for each device that responds.  For VXI/VME devices the driver includes a resman utility that is used to perform the resource manager function of the system.  VISA assigns resource descriptors to the devices that resman finds.
The overall process is this:
1)  Each individual driver finds its own devices that are attached. (NI-488.2, NI-VXI, NI-Serial, etc.)
2)  Using MAX, VISA is able to assign an instrument descriptor to all devices found.
3)  The application then uses a VISA resource control to address a device listed
(7,011 Views)
