VXI and VME
resman command line execution error
We have been using RESMAN as a command line execution for many years.  I have just installed LV8 on a brand new WinXP Pro machine.  Resman will run correctly with MAX, but when I run a command line execution, I get an error message as shown below:
If I run it programmatically from LV8 (which is the way we've always done it), I use the SYSTEM EXEC.VI  to implement the command line shown in the picture.  When I do run it this way, I get an error code out of SYSTEM EXEC.VI:  -1073741819
According to the ERROR CODE HANDLER, this code is not assigned.
AGAIN - RESMAN RUNS flawlessly from MAX.  It's only when I run either directly from a command window or programmatically to a command line execution that this error occurs.  (The windows popup error message occurs in EITHER of those cases, but of course, I only get the error code if run from LV8).
Anybody have any idea why this is happening?
Reece L. Bain, Jr.
Electronics Engineer, Stf.
Lockheed Martin Aeronautics Co.
(7,596 Views)
I PROMISE I searched the forum for the answer before I posted!!! 🙂
I just found the reference to the dll patch for resman and VXI 3.3.1.
It worked!  Sorry to press the panic alarm too soon!
Reece L. Bain, Jr.
(7,593 Views)
No Hard feelings Reece, we promise.  🙂
Just in case others are wondering, this is the patch he's mentioning.
http://digital.ni.com/public.nsf/allkb/851CD72FA50001B0862571100081237B
-Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(7,584 Views)
