VXI and VME
unable to initialize NI-VXI driver
When I tried to run "Resman", I got "Unable to initialize NI-VXI driver, unable to initialize kernal device drivers" error. My driver is NI-VXI/NI-VISA for PCI-MXI-2 and windows 2000/NT/9x (ver 2.1.1), the board is PCI-MXI-2 card. I connected the MXI cable between the PCI-MXI-2 card and VME-MXI-2 card (slot 0) in my VME chasis and power it on before ran it. My os is "Windows 98". If anyone has any suggestion, I highly appreciate.
(10,240 Views)
The error you are seeing indicates that the NI-VXI driver has not been started by your system. This could be because your system is not recognizing the PCI-MXI-2 card.
Did you install the software (NI-VXI driver) and then the hardware (PCI-MXI-2) or the hardware and then the software? If you installed the hardware in the machine before the software, then Windows 98 probably assigned an incorrect driver to the PCI-MXI-2 card. In your Device Manager, is there an entry for "VXI Devices" where the PCI-MXI-2 is listed?
If not, then you should shut down the computer and remove the PCI-MXI-2, reboot without the hardware in, shutdown the computer and reinstall the PCI-MXI-2 card.
If there is a listing for PCI-MXI-2 in the device manager, make sure your c
able is connected properly. The end of the MXI-2 cable with the white label should be connected to the PCI-MXI-2.
Also, there is a newer version of the NI-VXI driver. NI-VXI version 3.2 is available on our drivers download page.
(10,240 Views)
I am using VXI with LabWindowsCVI6.0 application.
I have PCI-MXI2 card in my PC and VXI-MXI2 in slot0 of VXI chassis.
NI DAQ version 6.6  was installed
Now i have one anthore PC in which i have installed LabView8.6  and DAQmx9.0 first then after i have installed CVI6.0.
I tried to install NI DAQ6.6 but i couldn't because i have already DAQmx9.0 exist in my PC
Now when i open CVI project which  i have develop earlier.I can not get DAQ help for VXI like "SCAN_Setup", "DAQ_DB_Config","DAQ_Config","GPCTR_Control",GPCTR_Set_Application" etc.
How i can have this NI-DAQ help which is coming in earlier version on START>>Programs>>National Instruments DAQ>> NI-DAQ Help
--Vishnu
(9,095 Views)
