VXI and VME
uninstall configtoolv2.zip
I installed the configuration file toolkit version 2 from the website http://zone.ni.com/devzone/cda/epd/p/id/4776. How do I uninstall this. I would like to install version 1 of this toolkit since it is more compabatible with my code which was written on a computer using version 1 of the toolkit.
Thank you,
Tim
(7,096 Views)
woops wrong forum. I should have posted this in the labview forum.
Sorry
(7,094 Views)
Hi Tim,
You can uninstall the configuration tool by going to Start->Settings->Control Panel->Add/Remove Programs and then removing Config Tool.  I tested it out and it worked on my computer.  Have a good Friday.
Brian K.
(7,086 Views)
