VXI and VME
vt1419
Has anyone programmed the Agilent Multifunction VT1419A (bought thru VXI Tech) in Labview?  I will be using the SCP card w/ 1533 and 1501 plug-in's.  It will be used for Analog Inputs/Outputs and Digital I/O purposes.  All the manual instructions seems to be examples pertaining to HP VEE.  If someone has some example code that has been done, I would be appreciative.  I attempted to inject a voltage on one of the analog channels and read it from the FIFO with NO success.  The function did not work.
Thanks.
G Mike
(6,960 Views)
G Mike,
Have you considered creating your own instrument driver using VISA? You can find resources to create your own instrument driver in the learn section of the instrument driver network homepage. Since you already have some commands in another language, it would require you to translate them into VISA commands.  Good luck!
-Marshall R
(6,949 Views)
