VXI and VME
what is the thread id?
When I get a error message pop up menu what is the thread id?  and what is it referring to?
(8,082 Views)
Hi Dusty,
In what context are you getting this message?  What hardware, drivers, and software (and versions) are you using?  Can you post a screenshot of the message?
Robert Mortensen
Software Engineer
(8,070 Views)
I'm using Labwindows 7.1 on a VXI chassis running Windows XP.  The error looks like this:
NON-FATAL RUNTIME ERROR
"D:\mde_823\Instrument Drivers\v241\ksv241b2c"
line 217, col 18 thread id 0.00000248
function viopen:{return value=-1073807300 [0.bffff003c]}.
insuffufficient system resources to perform necessary memory allocation.
I don't need to know what the error is I just need help understanding the thread id.  I get the same error quite a bit, but the thread id is different why is that?  What is it?
Dusty
(8,064 Views)
The thread ID simply refers to which cpu thread the code is running in.
Robert Mortensen
Software Engineer
(8,061 Views)
thank you for your help
(8,058 Views)
