VeriStand
[2019 R3] Compilation of Simulink model
Hello all,
 I've tried to compile a Simulink model for use with Veristand 2019 R3. I've done it before for NIVS 2018 (with Matlab 2016b) and it worked well. For 2019R3 though, there's a new *.tlc file introduced and Veristand Version Compatibility page says it needs a different compiler (MinGW instead of Windows SDK 7.1).
 I've managed to get the compilation running using Matlab 2018a with Matlab-provided MinGW compiler... There's one problem, though - the result of the compilation is an EXE instead of a DLL. Any suggestions?
 Thank you in advance!
 Veristand: 2019 R3
 Matlab: 2018a (Simulink, Stateflow, MinGW compiler)
Piotr F.
Hardware Engineer @ ZF
(2,255 Views)
Sorry for topic duplication - let's move the discussion here: https://forums.ni.com/t5/NI-VeriStand/Simulink-Model-compilation-attempt-results-in-an-EXE-file/td-p...
Piotr F.
(2,224 Views)
