VeriStand
ASAP3 with ATI
Hello all,
I am wondering if anyone has any experince implementing ASAP3 with VeriStand. I have no idea where to start.
I use VeriStand, and I use ATI as my calibration tool. I want to control ATI via ASAP3 using VeriStand. Is there anything that is readily available? If not, how would I even start going about developing it?
Thanks.
(8,639 Views)
We don't currently have anything off the shelf for NI VeriStand to make ASAP3 connections. However, you do have a few options:
  1. Try using the XCP/CCP Master custom device that is part of the ECU Measurement and Calibration toolkit instead of ATI Vision.
  2. Contact KGC (http://www.kgc.co.jp/index-en.html) as they are developing an ASAP3 custom device for NI VeriStand
  3. Develop your own custom device
Stephen B
(8,628 Views)
If you are going to write your own custom device, there is a developer guide to help you get started (warning: it's long):
http://www.ni.com/white-paper/12712/en
(8,626 Views)
An ASAP3 driver for the ETAS INCA was written in LabVIEW several years ago and is available to the public on the NI Forums.  It has been used extensively and updated by the user community.
NI VeriStand can support communication with ATI Vision and ETAS INCA through a modification to our ECU Measurement and Calibration Toolkit.  The work for this with regard to ETAS INCA has been completed by our Alliance Partners, KGC in Japan and Wineman Technology in the US, so you may contact them directly for this feature.  You may also contact NI through your local Sales office and they can put you in touch with our Automotive Networks or Real-Time Test contacts for a more detailed discussion.
(8,086 Views)
