VeriStand
About Real-Time analysis
I deploy simulink models to Pharlap RTOS through VeriStand,I m wondering how can we figure out whether our project is running in real time or not? Dose Veristand have some descriptions about how to make real time analysis?
(2,793 Views)
Accepted by topic author JACKY_z
One indicator of real-time behaviour of your model execution is whether or not it completes it's execution within the specified timing you set in the system definition file. To check this, you can use an indicator to monitor the "Model Count" System Parameter, which increments each time the execution finished late.
Additionally, if you see that the performance is not what you had hoped, you can also check the systems overall load with Tools >> Console viewer.
Remember Cunningham's Law
(2,753 Views)
