VeriStand
Actual Loop Rate is far below target rate, when i just add a asynchronous DAQ custom device
 I use cDAQ 9184 class with a NI-9411 to measure Speed and Torque frequency signal, i create a asynchronous custom device to meet my application, and there is a while loop in RT VI with 50ms wait, i deploy it to windows environment, it works, but the controller actual target loop rate become 25Hz, not what i set 100Hz, even i increase my controller target rate , it doesn.t help , so i wonder why, have someone met this situation before?  i will post pictures tomorrow.
Message 1 of 1
(3,664 Views)
