VeriStand
Add Message in "Error and Warning" or in "Output"
Hi !
I wonder if its possible to send message to Veristand Gateway from Linux RT Target.
I have the idea to create a VCD that will log Message to a file and if its possible to Veristand "Output" tab or to Veristand "Error and Warning"  tab.
Do you know if its possible ?
Thanks for your help....
(1,503 Views)
Well, not sure that I understand the question, but you can measure something in RT target and see the result in VeriStand.
So maybe you will be able to set specific data that can act in the way you want.
Can you concretize what exactly you need?
Thx.
(1,397 Views)
