VeriStand
Add calculated channel during execution
Hello everyone,
We would like to include a feature that we don't find in VeriStand.
Sometime, during the execution, we want to add a new calculated channel without stopping the test. It was possible to do that on Veristand competitor software like TestIn View.
We are wondering if there is a simple way to add this feature (with a VI or a Custom Device for example).
Is a feature like that, has already been done ?
Thanks for your answer !
(4,538 Views)
You have already tried to use API?
Certified LabVIEW Developer
GCentral
(4,533 Views)
Hello Pignite,
Are talking about VeriStand API .NET ? If yes, we already use it.
(4,530 Views)
I never saw such function in VeriStand.
You could suggest in the Idea Exchange for this feature in newer versions.
One workaround would be create as many calculated channels you need, and change their values as the simulation goes on.
Guilherme Correa
(4,509 Views)
I'm also trying to create calculated channels, not in veristand but in LabVIEW. how would I do this?
Storres211
(4,255 Views)
