VeriStand
Array setting for Rx packets channels in UDP custom device
I'm using the UDP custom device from the Github.
https://github.com/NIVeriStandAdd-Ons/UDP-Data-Link-Custom-Device
For the Rx packets, there'll be multiple channels of the packets as shown in the picture that will be mapped to Simulink model vector input with multiple elements. But it seems the channels of the UDP Rx packets can't be set to array and used to map with simulink vector input, does anyone has the solution? Thanks.
(1,670 Views)
Accepted by topic author tonygc2008
It's solved, set the Vector port to scalar channels, then map the UDP Rx Channels with this Input.
(1,639 Views)
