VeriStand
Assign results parameter in real time sequence to Veristand alias with API in Labview
I would like to be able to assign the result parameter of a real time sequence in Veristand to an alias with the stimulus profile API in Labview.
I have a VI that calls a CSV as a real time sequence and I am able to use the 'Get Sequence Info' VI to get a list of the parameters from the CSV. I would like to get the alias list for the project and assign the results parameters to aliases.  Any help is very much appreciated.
(3,344 Views)
Hi Jessieb,
You should be able to use the "Get Alias List.vi" in the LabVIEW stimulus profile API to pull in aliases from VeriStand applications. Then you should be able to use the System Definition API to modify aliases from there.
http://zone.ni.com/reference/en-XX/help/372846K-01/vsnetapis/lv_sysdef_overview/
(3,313 Views)
Hi ChaisePotato,
Thank you very much for your reply.  It was very helpful.
(3,297 Views)
