VeriStand
Build Error NMAKE for simulink model
I'm trying to set up the toolchain to build simulink models for Veristand. But I think I ran into the compatibility issues between Visual C++ compiler 2010, SDK 7.1 and .NET Framework 4.5+.
ERROR: The Windows Headers and Libraries are not installed.
Confirm support for the Microsoft Visual C++ compiler is properly installed. Visit www.ni.com/info and enter the Info Code ex3efp for a list of supported compiler configurations.
E:\Work\Simulatori\OL\OL_2015\Software\Modello Veristand\OL_Model\OL2015Model_niVeriStand_rtw>echo The make command returned an error of 1
E:\Work\Simulatori\OL\OL_2015\Software\Modello Veristand\OL_Model\OL2015Model_niVeriStand_rtw>An_error_occurred_during_the_call_to_make
'An_error_occurred_during_the_call_to_make' is not recognized as an internal or external command,
operable program or batch file.
### Aborted due to an error in the build procedure for model: OL2015Model
Following the link in the log gets here. I followed the instructions, installed the patch, same situation.
I tried multiple times reinstalling all the components: VC++, SDK and the patch. I'm still getting
the same error.
Anyone who solved the issue?
(5,766 Views)
What Windows OS version are you using?
Problem Installing the Windows SDK 7.1 for VeriStand Model Compilation
http://digital.ni.com/public.nsf/allkb/DD49A2842454008A86257F86004804FE
What Simulink version are you using?
Make sure its compatible with the compiler version you're using
http://digital.ni.com/public.nsf/websearch/10BBA745CD5A2FAE86257F9A0054FF71
Can you build using a non-veristand code generation and the visual c++ compiler?
Basically, I'm trying to isolate whether the problem is the VeriStand code generation make files inability to locate the compile tools vs a problem with Simulink Coder.
Interesting post on MathWorks discussion forum about installing 7.1 SDK:
https://www.mathworks.com/matlabcentral/answers/101105-how-do-i-install-microsoft-windows-sdk-7-1?re...
Tim A.
(5,743 Views)
I'm on Windows 7 SP1, Simulink r2015b (8.6) 64 bit.
The code generation was successful, the compiling wasn't.
I'm able to compile a simple model to an executable for Windows.
Whole log:
### VeriStand 2016.0.0.72 (2016) code generation started
### Invoking Target Language Compiler on OL2015Model.rtw
### Using System Target File: C:\VeriStand\2016\ModelInterface\tmw\target\NIVeriStand.tlc
### Loading TLC function libraries
### Initial pass through model to cache user defined code
### Caching model source code
### Writing header file OL2015Model.h
### Writing header file OL2015Model_types.h
### Writing header file rtwtypes.h
### Writing header file builtin_typeid_types.h
### Writing header file multiword_types.h
### Writing header file zero_crossing_types.h
### Writing header file rtGetInf.h
### Writing source file rtGetInf.c
### Writing source file OL2015Model.c
### Writing header file OL2015Model_private.h
### Writing header file rtmodel.h
### Writing source file OL2015Model_data.c
### Writing header file rt_nonfinite.h
### Writing source file rt_nonfinite.c
### Writing header file rt_defines.h
### Writing header file rtGetNaN.h
### Writing source file rtGetNaN.c
### TLC code generation complete.
### Generating TLC interface API.
### NI VeriStand 2016.0.0.72 (2016) Modifying source file OL2015Model.c
### NI VeriStand 2016.0.0.72 (2016) Modifying source file OL2015Model_data.c
### NI VeriStand 2016.0.0.72 (2016) Writing header file ni_pglobals.h
### NI VeriStand 2016.0.0.72 (2016) Modifying header file OL2015Model.h
### NI VeriStand 2016.0.0.72 (2016) Generating Ports Readme file
### NI VeriStand 2016.0.0.72 (2016) Generating Signals Readme file
### NI VeriStand 2016.0.0.72 (2016) Generating Parameters Readme file
### NI VeriStand 2016.0.0.72 (2016) Copying support files
        1 file(s) copied.
        1 file(s) copied.
        1 file(s) copied.
### VeriStand 2016.0.0.72 (2016) code generation done
### VeriStand 2016.0.0.72 (2016) code compilation started
### Processing Template Makefile: C:\VeriStand\2016\ModelInterface\tmw\target\NIVeriStand_vc.tmf
[Warning: VeriStand: You selected an unsupported compiler. Attempting to locate a supported installation of the Microsoft Visual Studio C++ tool chain.
VeriStand: Using the Microsoft Visual C++ 10.0 tools.
### OL2015Model.mk which is generated from C:\VeriStand\2016\ModelInterface\tmw\target\NIVeriStand_vc.tmf is up to date
### Building OL2015Model: .\OL2015Model_vc.bat
E:\[...]\OL2015Model_niVeriStand_rtw>set MATLAB=C:\Program Files\MATLAB\R2015b
E:\[...]\OL2015Model_niVeriStand_rtw>set VCINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\
E:\[...]\OL2015Model_niVeriStand_rtw>call "C:\VeriStand\2016\ModelInterface\tmw\toolchain\nivs_vcvars32_100.bat"
Setting environment for using Microsoft Visual C++ 10 x86 tools.
E:\[...]\OL2015Model_niVeriStand_rtw>echo The make command returned an error of 1
E:\[...]\OL2015Model_niVeriStand_rtw>An_error_occurred_during_the_call_to_make
(5,718 Views)
Did you solve your problem ?
Please help Smiley Embarassed !!!
Brice
(5,032 Views)
