VeriStand
CAN BUS VIEWER
I'm using a NI9862 module with a CRIO9081 in order to recover CAN data from an other device. I correctly power the module and configure the software with all the drivers.
My problem is that when i start the "BUS data viewer" under MAX, there is no data. But when i use PCAN with my device, PCAN find tha CAN data correclty...
Is there a special configuration under Max for the BUS viewer ?
(I've correctly set the rate, and the module drivers...)
(4,038 Views)
Same topic : http://forums.ni.com/t5/NI-VeriStand/CAN-BUS-VIEWER/m-p/3336910
Maxime G. | Application Engineer
National Instruments France
(3,996 Views)
