VeriStand
CAN error 1074388984 Windows 7
Hello Luca,
The 1.5ms is only for periodic frames.  I think a trigger channel would resolve this, as this should be implemented as an "event" frame.  You would have to trigger it yourself at the period you want.
The NI-XNET hw is not a direct replacement for NI-CAN hardware.  It is a new platform with a new API.  However, we have provided a compatibility layer that will make most of NI-CAN code work with on NI-XNET hardware.  We did also ensure that the NI-VeriStand CAN implementation would work with NI-XNET hardware.
I hope that clears things up.  Have a great day.
O. Proulx
www.ni.com/support
Message 11 of 11
(3,283 Views)
