VeriStand
CAN series-2 (8464) in Veristand 2010
Are Series-2 CAN interfaces (e.g. PXI-8464) compatible with veristand 2010?
If so, what is the procedure to configure the interface in System Explorer?
Thanks.
Luca
(6,030 Views)
Hi Luca,
as you can read in Veristand 2010 help (search for "NI-CAN"):
"NI VeriStand no longer supports NI-CAN. You can migrate existing system definition files containing NI-CAN and use them in NI VeriStand. However, you cannot add NI-CAN to a new project. Use NI-XNET instead."
Bye,
Licia
(6,016 Views)
Luca,
the official support for NI-CAN got dropped as Licia pointed out.
Though, if you add to the System Explorer.ini - <App Data Dir>\National Instruments\NI VeriStand 20xx\System Explorer\System Explorer.ini -  the following line, you will be able to configure NI-CAN on the chassis level:
NICANSupport = True
Make sure that the ini file has [System Explorer] as section specified, otherwise it won't work.
An alternative is to use the NI-XNET compatibility library. When NI-XNET got introduced, they wanted to boost the performance of customers that have been using CAN Series 2 but didn't want to upgrade to one of the new NI-XNET boards. When you install this additional component on the execution target, you will be most likely be able to use the NI-XNET configuration nodes in System Explorer to configure your system. Though, the new driver offers more functionality and it may not work with a Series 2 board. In that case, the only way to go is to use the INI token.
Tom
(6,011 Views)
