VeriStand
CRIO not visible under MAX
I'm using a CRIO 9081 wich worked well with MAX/VeriStand, but recently i reconfigured MAX and now, the chassis is no longer visible under remote system when i refreshed it...
Do i have to reconfigure the CRIO or reset the chassis and the IP to see it again ?
I tried the Automated Remote System Discovery Troubleshooting but it doesn't works.
Do you have an idea ?
(3,774 Views)
Accepted by topic author vincentlg
Did you try to:
-disable firewall
-reset ip of compactrio
-reinstall MAX
This link explain how to reinstall MAX.
http://digital.ni.com/public.nsf/allkb/D1F1D3FC80E4FFDF86256B410059DE31
Best regards.
(3,747 Views)
Did you try to:
-disable firewall
-reinstall MAX
Best regards.
(3,747 Views)
