VeriStand
Can't deploy when using FPGA config file
Hi all
I am new to NI Veristand. We are using a NIPXI 8108 controller having a NI 7841R FPGA card. The chasis used is NI PXI 1042Q.Veristand is not allowing to deploy, when we are trying to adding the FPGA target.For adding we used default FPGA config file for NI 7841R provided with veristand. The error is attached!. Without adding FPGA target we are able to deploy it.
We programmed the FPGA card using LabVIEW and it is working.
Please help us!
Sid
(6,330 Views)
please go through this attachment also...
(6,319 Views)
Accepted by topic author siddharthan_kannan
Hi Sid
It is because the FPGA card is not connected through the chassis
Right click on the PXI system(unidentified) and identify  it as PXI 1042Q.
Right click on the PXI 1042Q and identify  the controller as PXI 8108.
Then it will automatically populate the devices connected under the controller
Now try deploying it again. It will work
-SID
(6,306 Views)
