VeriStand
Can't open Versitand Project file created in win8 64bit enviroment.
I can't open veristand project file created in win8 64bit enrioment.
My development enviroment: Win7 32bit, Veristand 2012.
This is the error information
Error -307525 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NIVSSDF_Filemanager.lvlib:Load NIVSSDF.vi >> NIVSSDF_Filemanager.lvlib:Mutate To Current.vi
Possible reason(s):
NI VeriStand: Cannot open selected file. The file was saved in a later version of NI VeriStand.
can anyone help?
(5,737 Views)
you have probably different version of NI VeriStand installed. (I mean different patch).
Install lastest patch also on you Win7 32 bit computer. (NI VeriStand 2012 f2 Patch)
Jiri
CLA, CTA
(5,731 Views)
The problem is solved after the patch is installed. Thanks a lot for your information.
(5,712 Views)
