VeriStand
Cann't deploy xnet into RT with Veristand 2011
This is a known issue that occurs if you add signals manually instead of importing them from a dbc file. Do you have a dbc file with the signals and frames you'd want to import?
Jarrod S.
Message 21 of 23
(3,159 Views)
Hi Jarrod,
Thanks for the reply.
yes i do have the .dbc file created in max. I will check with that. cant we define the queue length for write/read and the loop rate of CAN write and read in veristand.
Please any tutorial to configure CAN in VS.
Message 22 of 23
(3,147 Views)
Thank you Jarrod.
I have used .dbc file created in Max and that works great with VS.
Message 23 of 23
(3,137 Views)
