VeriStand
Compile a Matlab Model with .slxp in NI Veristand
hello,
in matlab, i try to compile a model in Ni Veristand .
This model use a .slxp file ( a protected model ).
but i have an error :
Configuration component 'RTWSystemTargetFile' of model 'modele_base_ref_protect_r2013a' and configuration component 'RTWSystemTargetFile' of model 'modele_base_r2013a' are not compatible. The error message returned by the comparison function is:
The parameter setting for 'RTWSystemTargetFile' must be the same for all models in the model reference hierarchy
 If i change in matlab to compile with GRT.tlc , it's works fine  ( i have an .exe file ) .
have you an idea ?
i use Veristand 2014 and matlab 2013a 64b
thanks
(2,867 Views)
Hello alekus,
It means that you're using Reference Model in the model you're trying to compile. If the called-reference models are not parametrized the same way than the upper one, you won't be able to compile. In you case of application, are you able to update the Targets? (from GRT.tlc to NIVeristand?) Pay attention of the NIVeristand path declaration (addpath('C:\xx\VeriStand') + NIVeriStandPaths(2017)) => These are my settings.
R.
(2,726 Views)
