VeriStand
Compose UI from sub-UI
Hi all,
do you know if is possible compose a UI in NI Veristand UI manager, starting from other UI.
In other words, can I import *.nivsscr files into a root *.nivsscr and obtain a new user inetrface?
The reason of this question is due to a possible certification of my project, for this I would test every subsystem project and to do this in clear mode, decompose the main project in subsystem.
Regards
(3,551 Views)
Accepted by topic author ratataplam
a Veristand UI project can be composed of multiple UI screens! Every screen is then linked to a NI veristand project file.
The files cannot be merged together but you can run multiple of them in parallel.
Regards.
(3,505 Views)
Hi ratataplam,
In your Workspace screen, see the screen menu to manage the screen items. With it you can easily add or delete new screens.
I recommend you a veristand formation if you are not familiar with this tool.
(3,488 Views)
