VeriStand
Constant array assignments in stimulus profile
I'm trying to do two things with arrays in a stimulus profile:
1. Assign a constant value, e.g. MyArray = [1,2,3,4]  This fails on compile stating it is unable to parse beginning at '[1,2,3....'  I guess the work around is just to create/define the variable with this default value, but if I ever wanted to redefine the array I would have to indivually change elements, e.g. MyArray[0] = 5; MyArray[1]=6, etc.
2. Pass a constant array to another sequence, e.g. MyExpression(true, false, [1,2,3,4 ])  This fails in the same manner.
I'm scripting these profile's so I can work around these issues by just creating a local variable with the desired value as its default and pass that local to MyExpression. Am I missing something or array assignments and passing constant arrays not supported?  (VeriStand 2012)
(6,815 Views)
The Stimulus profile editor does not support that syntax for array constants. What you're finding is correct - you have to set the array values one index at a time within the Stimulus Profile Editor (although you could right a function to do it quickly for you). I believe passing the arguments fails because the Editor does not recognize [1,2,3,4] as an array. You would have to pass a variable defined as an array witht he values for the indexes set to 1, 2, 3 and 4.
(6,797 Views)
You might consider requesting this feature on ni.com/ideas. It does seem like it would be a good feature for making the use of arrays within the Stimulus Profile more user friendly.
(6,796 Views)
I was looking for this for a long time, I need this on most of my programs and is really annoying to need to assign values one by one. Must be an update for future versions.
(3,345 Views)
