VeriStand
[Custom Device] [Page.vi] about "Dynamic button pressed" event.
(6,362 Views)
You can create user-defined buttons that will be owned by a page. They come after the warning button and the separator :
This corresponds to the ButtonList and Button tags. If the type of a button is "Notification" (still a XML tag under Button), clicking on that button will send a user event to the page it belongs to, and you will be able to process that event in the event case you captured in your post.
You can refer to the tags here.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(6,226 Views)
A dynamic button is a button that is tied to a particular page. Once the page goes out of memory and a different page (with a different GUID) is loaded, the button(s) disappears.
Some more information about the Dynamic Button Pressed event
NI VeriStand Custom Device Developer’s Guide  Page 79
You can use elements in the Custom Device XML to configure custom user interface components, such as glyphs, toolbar buttons, and shortcut menus.
Adding Custom Glyphs, Shortcut Menus, and Toolbar Buttons
(6,222 Views)
