VeriStand
Custom workspace object Error
Hello Veristand Users.
I'm trying to use Veristand custom workspace object example on Veristand 2023Q3.
but it return error like below.
Any help and advices would be greatly appreciated.
NI VeriStand Add-on: Multi-Y Graph With Calculated Channels
https://forums.ni.com/t5/NI-VeriStand-Add-Ons-Documents/NI-VeriStand-Add-on-Multi-Y-Graph-With-Calcu...
-Build process on LabVIEW 2023 is successfully completed.
-And place build custom workspace vi and libray on "C:\Users\Public\Documents\National Instruments\NI VeriStand 2023\Display Templates"
However, it return error when place Graph object on Workspace like below.
thanks regard.
(893 Views)
Did you use 32-bit or 64-bit LabVIEW to build?
VeriStand 2023 is running 64-bit engine. I am not sure if the Workspace is built using 64-bit as well.
https://tmesystems.net/
(884 Views)
Hello ZYOng
thanks for comment
I use LabVIEW 2023Q3 64bit to build workspace VIs.
(871 Views)
