VeriStand
DAQmx Deployment Error for timeout
I occasionally get this error and am trying to track down the root cause:
The system recovers fine if I reboot the controller but that doesn't seem like a good long term solution. Looks to be happening every 2-3 days when the deployment is left running. When the next user tries to deploy a new image, the process appears to work fine up until I get this popup error. Any ideas of what might be the root cause or what log files I may need to chase down to find out what is happening?
VeriStand Version 2022 R3.
Don't have the PXI LinuxRT build information handy at the moment but can add it later if it matters.
(1,712 Views)
Click on Show more information to display the error reported. From there you can search ni.com for articles related to that error code.
https://tmesystems.net/
(1,697 Views)
I thought I had it before. I'll grab a screenshot the next time I hit it. Couldn't find anything useful for it on ni.com. I believe it was -200474 which was goofy since it's an analog out PXIe-6739 device.
EDIT: Seems to be related to the FIFO buffer. What settings do I change so that the FIFO doesn't hit this glitch?
EDIT2: Or alternatively, is there a way to have VeriStand clear the FIFO when it does a deploy prior to starting the DAQmx task?
(1,675 Views)
