VeriStand
Data Logging Control, dynamic file name
Hello
Is it possible to add tag in file name in the Data Logging Control that change automatically using a variable or a control? Example, I want to add the serial number of the unit under in each logfile name, but I don't want to open all data logging control and modify  all of them manually.
(4,347 Views)
I don't think there's a way to do this directly. You might look at the Post-Processing section of the configuration. One option you have is to run a command line operation on each file that is created. You could create a batch file or executable to rename the file at this point based on some criteria. Not a great solution, but worth considering.
Jarrod S.
(4,267 Views)
