VeriStand
Deploy a Veristand Project after deploying a LabVIEW project.
Hi everyone, I have a "problem" and I would like to know if there's another way to solve this.
The following problem happens:
  1. I deploy a Project from Veristand to my PXIe-8821.
  2. I'm done with the project and I close everything.
  3. I try to deploy a LabVIEW project to the same PXIe-8821:
  4. I get a "Conflicts" window.
  5. LabVIEW solves the problem and I can deploy my LabVIEW project.
  6. I try again to deploy a Veristand Project.
  7. Error Dialog.
  8. No Idea what to do.
  9. Workaround: I have to reinstall something or reinstall the Veristand Engine in the PXIe.
  10. Now I can do Step 1 and 2 again.
Is it the only way to do it?
Thank you.
Regards
My Channel: https://www.youtube.com/@LV_Lab
(2,612 Views)
Hi AldhairGarza,
You need to reinstall the VeriStand Engine to the PXIe controller via NI MAX. You can learn more at VeriStand Engine Removed After Running LabVIEW on Target.
You
Andy
PSE
(2,591 Views)
Just as Information it also works if I reinstall anything else.
Regards.
(2,579 Views)
