VeriStand
Deploying error
Hi ,
 I'm tried connecting the veristand environment using labview but i got this error. I'm using labview 2011 and vs 2011. Could anyone help me try to rectify the error.
(6,290 Views)
Make sure veristand is open
Stephen B
(6,288 Views)
Thank you, I opened the veristand and tried to run the VI it was working. I had a ERROR in the configuaration. I wanted to know is there any way to activate the veristand engine wihout opening the veristand.
(6,285 Views)
Hi jay090909,
you can use the silent gateway lunch you can found a zip with the
files under this post in the forum Open different Workspace files with VeriStand API.
best regards
Alexander
(6,263 Views)
