VeriStand
Diminished support for PXIe-4331 in VS2013
I am upgrading my system from VS2011 to VS2013. I have 7 PXIe-4331 bridge input modules installed across two PXIe-1075 chassis'. These modules were not natively supported in VS2011 and required a custom device add-on which was a free download from the ni website. The custom device fully supported the 4331 and was a very useful tool.
When I initiated the upgrade to VS2013 I went to the ni website for an updated version of the custom device and found that ni stopped updating it because the PXIe-4331 was natively supported starting with VS2012.
That's not entirely true. When I went to reconfigure my channels in VS2013 my only choice for bridge input was strain. The custom device offered a choice of strain, force, or pressure. All of the channels I am using are force or pressure inputs. Apparently, the force and pressure options were dropped when the custom device was implemented in VeriStand.
It's hard for me to believe that I am the first one to come up against this. Is anyone aware of a work around for this issue? Can the custom device for VS2011 be easily modified to work with VS2013?
Message 1 of 11
(8,497 Views)
Hey Pmac,
When I deprecated the 433x custom device support I had forogtten about these measurement types. Sorry about that. I don't want to continue updating that custom device, so I will post a download on that page that adds in Force and Pressure to NIVS 2012 and 2013 in an hour or two.
Stephen B
Message 2 of 11
(8,464 Views)
OK posted. Let me know how that goes
https://decibel.ni.com/content/docs/DOC-15404
Stephen B
Message 3 of 11
(8,450 Views)
I also reported this as a feature request to NIVS as CAR #456029
Stephen B
Message 4 of 11
(8,444 Views)
I just fixed a bug with pressure so if you already downloaded that, redownload it.
Also, I added torque for completeness.
Also, apparently this was already reported in CAR # 426506, so if you're tracking them... track that. The other one was closed as a duplicate
Stephen B
Message 5 of 11
(8,436 Views)
OK, Thanks.
There are a couple of issues with the force plugin. I've been working over the phone with Ryan C. he said he would get with you about these.
Thanks for the update.
pmac
Message 6 of 11
(8,429 Views)
Stephen B,
There still seems to be a bug with the pressure plugin.
When I added a couple of  pressure channels and deployed the SDF, error -307526 "The XML file provided is invalid." was reported in the deployment log.
Message 7 of 11
(8,398 Views)
Hmm I just tried it and it works... Can you try clearing out the plugin and reinstalling it?
Stephen B
Message 8 of 11
(8,395 Views)
OK. Now it works.
Message 9 of 11
(8,392 Views)
Stephen
Any idea what happen to that post?
I am working with a 4339 and would like the force or custom voltage with excitation measurement type.  I would also like the ability to use the shunt cal on the terminal block.  I have a DAQ plugin for 2013 that adds support for shunt cals, but can't port it over to 2014 as the VIs are stripped.
Is there any documents that discuss creating these DAQ plugins?
Thanks.
Rob
Message 10 of 11
(6,286 Views)
