VeriStand
Does veristand support co simulation with rt target (pxi) and simulink
Does veristand support co simulation with RT target (pxi) and simulink MDL... If so kindly share me related implementation document
(Note: we already implemented .dll based model)
(6,607 Views)
Accepted by topic author siddharthan_kannan
Only the PC engine can do co-simulation directly with Simulink. You cannot use an MDL file directly on an RT target. This type of co-simulation is definitely not real-time, and is not suitable to run on an RT Target that is performing other time-critical tasks. You can have multiple targets in your system definition, so you could have an RT target and a PC target. But you would need some means of communicating between the two target types. This might involve a model or custom device.
Jarrod S.
(6,534 Views)
Thank you jarrod
I have tried converting PC to another target and used NI VeriStand Add-on: Reflective Ethernet Custom Device by Prevas to communicatebetween host and the controller
but this method hangs the veristand. We required this to happen because we have plant model in dynasty ( caterpillar software ) which is not stable as .dll
(6,513 Views)
@siddharthank@yahoomail.com wrote:
Thank you jarrod
On the behalf of the Ethernet Custom Device hanging VeriStand.
I am interested in a bug report of this issue.
Can you elaborate your problem(s) further?
Br,
/Roger
(6,286 Views)
