VeriStand
Edit/Create database LIN with NI-XNET
Hello everyone,
From the system explorer VeriStand you can import, and use with the card XNET, file .ldf already edited but you can not edit them with the database editor apparently does not support the LIN protocol.
Someone has found the same behavior?
How do I create / edit configuration files LIN?
Thank yuo very much
monica
(6,151 Views)
Monica,
NI-XNET in general neither supports to create nor to edit an LDF file.
For now, as long as NI-XNET doesn't provide that support, you might want to check out 3rd party tools.
Sorry for the inconvenience!
Tom
(6,147 Views)
