VeriStand
Embedded Data Logger does not work
i installed everything like Veristand writes in the Help window , but the Embedded Data Logger does not function.
Where could be the Problem. When i start the Trigger there is no generated Log File.
I generated a boolean switch on the UI, is that ok for the Log Trigger?
(3,412 Views)
Embedded data logger can log at PCL rate or slower. If you need to log faster then the PCL rate (1MS/s in your case), create a Waveform task instead. Check this out
CLA, CTA, CLED
(3,360 Views)
Thank you for this very nice description!
Now it works, but the only problem i have now is a anomal time line with values like: 1014968:48:38,250. What could be the reason for this?
(3,327 Views)
I cannot open the link anymore, how does it work out now?
Best regards
(2,975 Views)
