VeriStand
Error 2 while generate a LV model
when I try to generate a model for Linux x64 target I received this error:
Error 2 occurred at System Exec.vi. Command was ""C:\build\17.0\x64\sysroots\i686-nilrtsdk-mingw32\usr\bin\x86_64-nilrt-linux\x86_64-nilrt-linux-gcc.exe" -shared -g -O2 -fPIC -Wl,-Bsymbolic -I"C:\Program Files (x86)\National Instruments\LabVIEW 2020\cintools" Untitled3_core.c --sysroot="C:\build\17.0\x64\sysroots\core2-64-nilrt-linux" "C:\Program Files (x86)\National Instruments\LabVIEW 2020\AppLibs\Linux\x64\lvdll.a" -o Untitled3_core.so"
Possible reason(s):
LabVIEW: (Hex 0x2) Memory is full.
No Listeners on the GPIB.
Error occurred. No DLL produced.
The model that I'm trying to create is a simply while loop with a control and an indicator.
Thank you,
Fabio
(2,883 Views)
I have the same problem, did you have any progress on this issue?
(2,694 Views)
I reinstall LV.
Fabio
(2,671 Views)
I too have the issue.
does re-installing solves the issue?
(2,183 Views)
I did it and I solved. Hope it works for you too... 🙂
(2,178 Views)
Thanks will try! 😊
(2,175 Views)
